Got My 8.8 Installed
battallion14
PostPosted: Sun Nov 21, 2004 8:15 pm    Post subject: Got My 8.8 Installed Reply with quote
I got my 8.8 swap done today. The old Dana turdy five is resting happily in the garage. Believe it or not I was able to use the stock upper control arms, no SYE and 1" of TC drop and managed to achieve 1 degree of U joint cancellation in the drive line. Yes, that's right, stock uppers and a slip yoke and no vibes! I have some minor things to finish up. I gotta tap the new breather hole I drilled since I am reusing the TJ T for the brakes and breather line and tack a bolt into the old breather hole. I also need to get some 1/8" C channel and fab two swaybar brackets. To reuse the TJ brake/breather line T all you need is another PASSENGER side rear brake hose to put on the DRIVER side of the axle. The TJ hardlines can be used, but they will be a bit long. This swap also netted me an inch of lift in the rear (about 1/2" from the difference in size of the axle and another 1/2" in the height difference of the spring pads. I have to say, the difference between disc brakes and drums is night and day. The Jeep brakes a lot better than when it was stock on 31's with drums. Thing stops on a dime. I still have about 2" of clearance from the tire to the upper spring perches (12.5" wide tires). Now I need to take it down to Uwharrie and do a test run. Here are some pics for ya folks.
D35
Ford 8.8
Magical Invisible Axle
D35
Ford 8.8
One more 8.8 Pic
'00 TJ Sport
View user's profile Send private message Visit poster's website MSN Messenger
