ZJ Info needed
Jeep Iceland
PostPosted: Thu Nov 25, 2004 1:22 am    Post subject: Reply with quote
Embarassed I thought you were talking about this Embarassed
As for the actual towing hooks rofl ....none there just one small loop Crying or Very sad
Im gonna start looking for a 242 today,Im sure they want a arm and a leg for it pissed
How much is a used one in good cond. where you live?
F.D
1996 Limited 5.2
http://www.cardomain.com/id/461ponchos96jeep
1976 Trans Am
http://www.cardomain.com/memberpage/531601
PostPosted: Thu Nov 25, 2004 1:33 am    Post subject: Reply with quote
Around here you can get one for $200 or so.. Maybe less if you get lucky..
Goerge at Transfercases unlimited.. Sells them Ready to install for $800 or so... Rolling Eyes
Maybe you can get one for a good price.. Good luck..
KevinsJeepparts sells radiator supports with tow hooks or shackles on them..
www.Kevinsjeepparts.com
Jeep Iceland
PostPosted: Thu Nov 25, 2004 4:18 pm    Post subject: Reply with quote
Thats a Dana 44 right?
F.D
1996 Limited 5.2
1976 Trans Am
PostPosted: Thu Nov 25, 2004 5:48 pm    Post subject: Reply with quote
Kind of a bad angle but Looks like it has flat sides ..
If its sorta shaped like a stop sign then its a 44 ..
If its mostly round its a 35.. Oh and 44 in a Grand would be aluminum .. There fore a magnet will tell you right away...
carl
Jeep Iceland
PostPosted: Fri Nov 26, 2004 1:16 am    Post subject: Reply with quote
Here is a 35 cover on ebay looks round like you said:
Here is a 44 cover....looks like mine:
Now Im going outside with a magnet Razz
F.D
1996 Limited 5.2
1976 Trans Am
Jeep Iceland
PostPosted: Fri Nov 26, 2004 1:31 am    Post subject: Reply with quote
Yeah its official its a 44 my huge magnet didnt stick on there. Very Happy Cool headbang crazy jeep
F.D
1996 Limited 5.2
1976 Trans Am
PostPosted: Fri Nov 26, 2004 7:07 am    Post subject: Reply with quote
Good for you .. A 44A with a limited slit...And you got factory skids and tow hitch... How can you beat that...
Go out and wheel that thing.. Mr. Green Mr. Green
How many miles on that thing??
Jeep Iceland
PostPosted: Fri Nov 26, 2004 9:44 am    Post subject: Reply with quote
86.000 miles Im the 3rd owner,very smooth ride and off-road capable too gotta love it Cool
Next summer when Im done with my Pontiac Ill start on the 242 project and maybe a airlocker for the front......and replace that driveshaft.
F.D
1996 Limited 5.2
1976 Trans Am
andyoet
PostPosted: Mon Dec 13, 2004 5:19 pm    Post subject: xj axles Reply with quote
i can eliminate cv axles with xj axles right
how hard is that to do and what do i have to do
PostPosted: Mon Dec 13, 2004 6:32 pm    Post subject: Reply with quote
Very simple. Just pull out the CV's and put in the U-jointed shafts..
You will loose ABS.. So pull the ABS relay and fuse out from under the hood.
Mr. Green Mr. Green
andyoet
PostPosted: Tue Dec 14, 2004 7:49 pm    Post subject: xj axles Reply with quote
do i have to pull the diff cover and pull the whole axle
PostPosted: Wed Dec 15, 2004 7:54 pm    Post subject: Reply with quote
Nope dont have to pull the diff cover.. It will slide right out.
Dana 30 is a semi floating axle .. NO c-clips but cant be driven without outer axles..(The hub is held together by the outer axle..)
