Bad alternator?
jblade
PostPosted: Fri Dec 03, 2004 2:10 pm    Post subject: Bad alternator? Reply with quote
My 2000 Wrangler won't start without a good jump. I got it going, kept it at 2000 RPMs for about 2 minutes, let off the gas and it stalled out again. Restarted, same thing.
The battery is good.
Is it a bad alternator?
Thanks.
2000 Wrangler Sport - 32's
PostPosted: Fri Dec 03, 2004 2:20 pm    Post subject: Reply with quote
Possible. How do you know the battery is good?
This is my line of thought. If the battery were good, it should start under it's own power but will discharge the battery as the engine runs. Likely, your battery is shot. But more so from being drained by a potentially bad alternator.
T.O.W. Vehicle
PostPosted: Fri Dec 03, 2004 3:04 pm    Post subject: Reply with quote
I would think too the battery is shot. Go to Advanced and have it checked, I bet the outside cells are bad.
"T.O.W. "= Tent On Wheels.
Best Top Sailcloth RAT
RE 4.5"Super Flex Lift
AA HD SYE
JKS Quicker Disconnects
Shrockguards
CoreyXJ
Turkish
Turkish
PostPosted: Fri Dec 03, 2004 3:31 pm    Post subject: Reply with quote
On a 2000 model year I would blame the battery first. I bought a brand new car back in 98 and it had a dead cell in the battery so it was bad almost immediately. One thing you can do to check the system is
A) See if it starts by itself with no jump... If not bad battery
B) Once it is running (jumped or not) unhook the negative terminal on the battery and see if it stays running. If it runs for a minute and eventually dies...bad alternator.
CoreyXJ
jblade
PostPosted: Fri Dec 03, 2004 5:18 pm    Post subject: OK, I'm a jackass Reply with quote
I purchased a new battery about 5 months ago so I assumed that it wasn't dead, I was wrong. Dead battery, easy fix and 100% under warranty. Thanks guys/gals.
