Frame brace
elbm
PostPosted: Sun Dec 19, 2004 3:58 pm    Post subject: Frame brace Reply with quote
last summet I read an article on a frame brace for the Jeep Cherokee. The brace went from one corner to the other and was bolted in place the welded. It was supposed to reduce body flea. I can not remember the name of the companey that made it. Anyone else read about it ? (and know how to contact them) Thanks....
88greenxj
PostPosted: Mon Dec 20, 2004 4:47 am    Post subject: Reply with quote
you can go to your local steel shop and get 3x3 angle iron and have sombody weld it to your sub frame it works great ive got 2 buddies that have dont it to there xj can be flexxed out and still open the doors and rear hatch with no problem
88 xj 9.5 rustys lift custom 2 link front suspension 36 inch tsl
elbm
PostPosted: Mon Dec 20, 2004 8:32 pm    Post subject: Reply with quote
Sounds good to me. Can you tell me how long a piece of angle iron I meed and where to weld it too? Thanks...elbm
88greenxj
PostPosted: Tue Dec 21, 2004 4:35 am    Post subject: Reply with quote
i will get you a measurement on it tomorrow
935speedxj
PostPosted: Mon Jan 10, 2005 9:04 pm    Post subject: Reply with quote
could you send pics of what an how this would look like setup?
PostPosted: Wed Jan 12, 2005 8:44 pm    Post subject: Reply with quote
Here are a couple that I found:
http://www.tandjperformance.com/products-bpp-xj-chassiskit.htm
http://www.tandjperformance.com/products-bpp-xj-stage2chassiskit.htm
Aftermarket bumpers or hitch receivers would help strenghten the unibody as they will tie the rails together, forming a box. Add a couple of beefy peices of angle iron welded to the rails (as stated above) and you should be pretty set...for a lot cheaper too. Wink
