Is this a good deal?(yup its me again)
Huey
PostPosted: Fri Dec 24, 2004 10:37 pm    Post subject: Is this a good deal?(yup its me again) Reply with quote
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7942773354&category=33585
It says i dont need a new SYE. and its a 4.5" kit.
Huey
PostPosted: Sat Dec 25, 2004 9:26 am    Post subject: Reply with quote
^The thing i saw about it was that no SYE needed. And im gettin low on money and its also free shipping..hmmm.
CoreyXJ
Turkish
Turkish
PostPosted: Sat Dec 25, 2004 11:36 am    Post subject: Reply with quote
I don't understand how a 4.5" lift and a 1" t-case drop all equates to no SYE needed. I have also heard mixed views on Rough Country stuff....
It looks like the kit doesn't have the actual extended brake lines...It says "extension brackets" which probably relocates the rear brake line - bad idea. It says "sway bar drop bracket" which is kind of silly to do when you can get a nice set of longer disconnects (which the kit doesn't come with) and leave the sway bar where it is. You are also going to have to press in your bushings in those lower control arms. Unless you have a press, you may damage the bushings trying to put them in. The shocks I am assuming are Heckethorns which are pretty ok.... Also the rear lift relies on an add-a-leaf with blocks....Thats also a questionable way of doing it, because a lot of times blocks can be problems later on.
I have heard people call it just that - rough. If you think this is the way you want to go then, by all means get it while you can.
CoreyXJ
Huey
PostPosted: Sat Dec 25, 2004 12:10 pm    Post subject: Reply with quote
Do you think its a good deal? $$$ wise it sounds great, but u said uve heard mixed feelings..also would i not need a new drive shaft either? Thanks alot Corey..merry xmas!
PostPosted: Sun Dec 26, 2004 7:37 am    Post subject: Reply with quote
Pretty much what Corey said. AAL's will sag over time, blocks cause axle wrap...neither is good for the leaf springs. I've also heard that Rough Country inflates the actual amount of lift netted. So, for example, on a 4.5" advertised lift you might only net 4" (or less).
The bottom line...you get what you pay for. My advice? Don't try to scrimp and save by purchasing less than quality parts...you'll just end up redoing it later. Do it right the first time.
CoreyXJ
Turkish
Turkish
PostPosted: Sun Dec 26, 2004 1:29 pm    Post subject: Reply with quote
Negative Ghostrider..... I don't think its a good deal. Maybe for the money, but like thephantum said... You get what you pay for
CoreyXJ
Merry Xmas to you also !! Very Happy
Keithtj
ARLI$$
ARLI$$
PostPosted: Mon Dec 27, 2004 10:28 am    Post subject: Reply with quote
Huey one of the worst things in the world and we've seen it a hundred times is when some one picks out a cheap lift and when they get find out that they still need to get more stuff to make it work! You do pay for what you get. You have a list of good lifts to go from that are not to expensive. Stick with one of Rubicon Express or the Fab Tech. Trust me you'll be happier in the end. With 4" of lift there is a 95% chance that you will have to do an SYE even if advertised that you don't!
My Morning Jacket
88greenxj
PostPosted: Tue Dec 28, 2004 4:33 am    Post subject: Reply with quote
ive been runing that same kit on my xj for two years with out problem the lower control arm bushing went in easy and ive been beating the crap out of it since the day it went on the jeep hell it survived tellico
88 xj 9.5 rustys lift custom 2 link front suspension 36 inch tsl
88greenxj
PostPosted: Tue Dec 28, 2004 4:35 am    Post subject: Reply with quote
oh yeah and im not using a sye on mine just the t-case drop
ecrab3
PostPosted: Tue Dec 28, 2004 8:19 pm    Post subject: Reply with quote
Here ya go Huey, if your going with a 4.5" lift, a sye is pretty much a safe mod that cant go wrong. This is alot cheaper than what I paid, next money is $260 for a new driveshaft.............
http://www.jeepforum.com/forum/showthread.php?t=114231
good luck with whatever you buy
97 XJ with some stuff
View user's profile Send private message Yahoo Messenger MSN Messenger
