Intermittent noise over 55 mph?
Ivan
PostPosted: Fri Dec 31, 2004 9:47 am    Post subject: Intermittent noise over 55 mph? Reply with quote
I have a 1997 Grand Cherokee Limited. Have driven over 129,000 miles. Terrific automobile -- no major problems to date. Recently I have been hearing an intermittent noise (vroom vroom) when I drive over 55 mph. Does not have any noticeable effect on driving. Can anyone advise me on the source of this noise. Many thanks. :)
Jeepster
detox
PostPosted: Fri Dec 31, 2004 1:02 pm    Post subject: Reply with quote
U joint, maybe. check the diff fluid lately?
tranny fluid ok?
brake pads may be chattering
off the top of my head..
Chicks Below Me...
jeepzj9304
PostPosted: Mon Apr 25, 2005 6:52 pm    Post subject: Reply with quote
if your driving over 55 mph than you have to really worry about the u joints. the only time you have to worry about the u joints is when you are turning shaprly in 4wd and you will hear a clatter and poping sound. i had that exact same problem last week my jeep was making a humming sound. most likely it is the wheel bearings.
PostPosted: Mon Apr 25, 2005 7:09 pm    Post subject: Reply with quote
Yup... Check your wheel bearings.. If it where a U joint (front shaft specifically ) you would feel a vibration in the floor..
grocery getter 318
PostPosted: Thu Nov 17, 2005 12:12 pm    Post subject: Reply with quote
i had something like that at 40 mph and it turned out to be an ovaled front output shaft bearing on the 249.
HIRE THE HANDICAPPED THEY'RE FUN TO WATCH
leadsled
PostPosted: Mon Jan 16, 2006 2:29 pm    Post subject: Reply with quote
I had the same thing. Turned out to be a bad drive axle, cv axle. $89 and about an hour to swap, took care of it. Now if I could just get my heat to work...
Josh
