removal of rear pinion shaft
g2buymore
PostPosted: Sat Jan 08, 2005 1:12 pm    Post subject: removal of rear pinion shaft Reply with quote
How do you remove pinion shaft after removal of yoke?
PostPosted: Sat Jan 08, 2005 2:22 pm    Post subject: Reply with quote
You need to remove it from inside the differential. It requires pulling the axle shafts and the carrier.
Why do you need to remove the pinion?
