possible vapor lock problem?
chappy
PostPosted: Mon Oct 03, 2005 6:28 am    Post subject: possible vapor lock problem? Reply with quote
I have a 86 cj7 with a 80 model year 360. During hot weather it stumbles violently. I have traced this back to the fuel pressure. I installed a new mechanical pump. It did not fix it. So I installed a 10-14 psi electric pump. Since the weather has been cooler (and I have been running short trips) I have not noticed the problem. Saturday while driving home after idling in a drive through which got the Jeep good and hot it started again. This was after driving 60-65 miles per hour for 5min. That puts the RPM's at about 3100. I put a pressure gauge on it Sunday and when I started it (cold) I had 11psi. I let it idle for 15-20min and I heard the engine die. I went out and restated the hot motor and I was showing 2-3 psi.
I have a new fuel tank/sending unit. I have ran new fuel line forward from about the rear axle getting the line away from the exhaust. My electronic pump is mounted at the bottom of the passenger fender. This maybe to far forward ( I know that electric pumps are better pushers than pullers). If you have any ideas they would be appreciated. Thank you in advance.
Matt
wqrt
PostPosted: Thu Oct 06, 2005 4:53 am    Post subject: Reply with quote
I think I'm experiencing the same problem on my `80 CJ-7. When it gets hot it will puke black smoke and act like it is choking itself out then stall. Then it doesn't want to start again. Is this similar to what your experiencing? If so I'll keep checking back to see if anyone has the answer to fix the problem.
chappy
PostPosted: Thu Oct 06, 2005 6:12 am    Post subject: Reply with quote
My Jeep doesn't smoke. It just looses fuel pressure and dies.
I did move my pump back next to the tank. This did not help. I am going to drop the tank to check for obstructions.
Matt
