gearing
nikon
PostPosted: Fri Jan 14, 2005 10:05 am    Post subject: gearing Reply with quote
who feels like teaching me about gearing? Very Happy
Why you need to do it with bigger tires? Advantages? when so the advantages come into play? What do the numbers mean? How I know what I have?
Thanks
LISTEN TO BLACK SABBATH
FM2CDJC Member #10
9. Thou shalt not kill. Unless some motherf****r is coming into your house to take your s**t! - The Nuge
PostPosted: Fri Jan 14, 2005 11:18 am    Post subject: Reply with quote
Gears are used to increase or decrease speed of rotation. In regards to axles, they decrease the rotation of the tires in relation to the driveshaft. So, for example, if you have a 3.55:1 gear ratio, the tires spin 3.55 times everytime the driveshaft spins once.
As you go to bigger tires, the wheels have to turn less to cover the same distance...in other words, you will travel farther on one revolution of a 33" tire than you would on a 30" tire. The changes the RPM of the engine at a given speed. For example, using 3.55 gears at 55mph, a 30" tire will spin the engine at 2,181 RPM...but a 33" will spin the engine at 1,982 RPM. What you end up noticing is an apparent power loss.
Re-gearing brings the RPM range back up again, resorting the "lost" power. In the above case regearing to 3.90 or 4.10 would bring the RPM's back into the 2200 RPM range at 55 MPH.
Make sense?
Billy's89XJ
PostPosted: Fri Jan 14, 2005 11:20 am    Post subject: Reply with quote
Make sense?
Well said! Mr. Green
nikon
PostPosted: Fri Jan 14, 2005 4:40 pm    Post subject: Reply with quote
you just explained that in a way I could understand it. that is not an easy task my friend. For this you get a gold star Very Happy
FM2CDJC Member #10
WhatWasIThinkin
PostPosted: Sat Jan 15, 2005 6:25 am    Post subject: Reply with quote
rofl
Real Jeeps dont wear Bra's
PostPosted: Sat Jan 15, 2005 9:08 pm    Post subject: Reply with quote
nikon wrote:
LOLOL OMG!!!
I swear to God when I saw that pic... spit
That is classic!!! too funny
nikon
PostPosted: Sat Jan 15, 2005 10:43 pm    Post subject: Reply with quote
you all know how little I know about engines and such...you're doing something right if you can make me understnad what you're talkin about.
that and I was bored at work Mr. Green
FM2CDJC Member #10
MN Dave
PostPosted: Thu Apr 21, 2005 10:54 am    Post subject: Reply with quote
Make sense?
I'm probably not much more knowlageable then Nikon, but wouldn't a 3.55:1 gear ratio mean, the tires spin once times everytime the driveshaft spins 3.55 times, not the other way arround?
99TJ
PostPosted: Fri Dec 23, 2005 10:43 am    Post subject: Reply with quote
MN Dave, you are correct. Your R & P are reduction gears.
