Service 4 wheel drive switch??
Goto page 1, 2  Next
95zj
PostPosted: Thu Jan 20, 2005 2:04 pm    Post subject: Service 4 wheel drive switch?? Reply with quote
i have a 95zj and for the past few weeks the VIC will beep and service 4 wheel drive switch comes up. If u give the switch a smack forward it usually goes off, but i want to fix this problem now. Does anyone know what needs to be tightened of adjusted, i got under there and screwed around but cant seem to find a way to adjust it. Thanks.
THIS JEEP IS NOT AN SUV
YOUR SUV IS NOT A JEEP
ITS A JEEP THING
95zj
PostPosted: Thu Jan 20, 2005 2:32 pm    Post subject: More info. Reply with quote
If you need me to be more specific its the 5.2 V8 and has the 249 TC
ITS A JEEP THING
PostPosted: Thu Jan 20, 2005 5:29 pm    Post subject: Reply with quote
If you are hitting the gear selector and the light goes out.. Try adjusting the shifter a little..
You will see it on the side of the t case..
If that doesnt work... Maybe the switch is going out.. They are available at the dealer...
Wicked Iy
PostPosted: Wed Feb 16, 2005 7:40 am    Post subject: 4 wheel drive switch Reply with quote
Where can i find the 4 wheel drive switch for a 93 Grand Cherokee 5.2 engin. I'm trying to solve the service light in my Jeep. Can any one help/telll me.
It's A Jeep Thing.
A Wild Thing!!!
PostPosted: Thu Feb 17, 2005 5:14 am    Post subject: Reply with quote
The Mode selector switch is actually on the tail of the transfercase...
There are two plugs .. ONe is for speedo .. And the other (4 wires ) is for the mode selector switch.. I was telling him to check the plugs behind the VIC ... You take outthe 6 screws in the surround and take out the VIC and then check all the plugs..
Goodluck..
Carl
93ZJ
PostPosted: Thu Feb 17, 2005 12:25 pm    Post subject: Reply with quote
the switch u r looking for will be on the tranfer case, near the front drive shaft
jbjonesy7
PostPosted: Mon Mar 07, 2005 1:18 pm    Post subject: I'm having the same problem Reply with quote
I'm having the same problem. The dealership said it needs to be adjusted and wants 40 bucks. I figure if it costs so little it must be something i can do myself. Can you be more specific about how i can adjust this by myself. What tools i will need and how hard it may be? Thanks. Maybe a picture of diagram would be helpful.
PostPosted: Mon Mar 07, 2005 2:16 pm    Post subject: Reply with quote
I think its a 14mm ... Just look under the jeep you will see the linkage on the side of the t case.. Loosen the 14mm bolt and pull it back a tiny bit... See how that does..
Carl
jbjonesy7
PostPosted: Mon Mar 07, 2005 6:53 pm    Post subject: Reply with quote
is there a possiblilty i can get a picture of the parts? I do not know which bolt to turn to put the GC back into 2WD! I did loose the bolt on the linkage bar but did not know i needed to turn anothe bolt.(no wonder the Part_time light is still on.
PostPosted: Mon Mar 07, 2005 8:42 pm    Post subject: Reply with quote
I will crawl under mine tommorow and take a pic.. I am in the middle of drawing a wiring diagram for electric fan.. (I guess I will add that to the writeup...)
Carl
jbjonesy7
PostPosted: Mon Mar 07, 2005 9:01 pm    Post subject: Reply with quote
IT would be greatly appreciated. I'll check back tommorrow for the ppic. Please use a couple of arrows for me also. Thanks!
jbjonesy7
PostPosted: Thu Mar 10, 2005 7:34 am    Post subject: Reply with quote
still in need of help. I am told driving it like this will damage the tranns
jbjonesy7
PostPosted: Fri Mar 11, 2005 10:12 am    Post subject: Reply with quote
anyone got a photo or someting of it?
PostPosted: Fri Mar 11, 2005 5:40 pm    Post subject: Reply with quote
Sorry I havent gotten the photo yet.. I had the craziest week ever at work... Every refrigeration unit in the entire restraunt crashed on me and I had to get them all back going ... IT sucked.. (even the beer coolers where out.. That hurt the most... Shocked )
Anyway.. I will draw the wireing diagram to add to the Electric fan writeup and take pictures of the linkage tommorow... So very sorry...
Carl
PostPosted: Fri Mar 11, 2005 5:58 pm    Post subject: Reply with quote
Also had to go and pick this up Yesterday....
Mr. Green
Just want to say... Pretty damn fast ..... Mr. Green
Goto page 1, 2  Next
Page 1 of 2
