Popping Noise
Post new topic   This topic is locked: you cannot edit posts or make replies.     Forum Index -> Cherokee Forum
XJGuy
PostPosted: Wed Feb 02, 2005 7:58 pm    Post subject: Popping Noise Reply with quote
I have a 96' Cherokee with the straight axle on the front. I am getting a popping noise somewhere around the front of the car...It occurs when I turn at low speeds, like 0-8mph on dry or wet pavement in 2 wheel drive. I have run the car in both 2 wheel and 4 wheel on ice and snow and the popping noise does not occur. It is usually a sequence of pops as I turn the wheel. U joints on the axle and wheel bearings seem fine. It also seems to only pop when I am rolling and it happens in both foward and reverse, and both directions turning the wheel. Are there any tests or things I am missing... bent shock piston, sway bar?? Has anyone else experienced anything similar to this? Any info would be greatly appreciated. Thank you
PostPosted: Wed Feb 02, 2005 8:03 pm    Post subject: Reply with quote
Locking this one. There's one in Drivetrain...no sense in having duplicate threads in two subforums. Wink
PM me with any issues.
Post new topic   This topic is locked: you cannot edit posts or make replies.     Forum Index -> Cherokee Forum All times are GMT - 8 Hours
