My TJ with no radio antenna....is it rare?
TJfreak
PostPosted: Sun Jan 30, 2005 9:11 pm    Post subject: My TJ with no radio antenna....is it rare? Reply with quote
Hey,
When I bought my TJ in October it came with no radio antenna, Still has none. How much would it cost to get one and where??
Anyone have a TJ with this problem?
thanks
View user's profile Send private message Yahoo Messenger MSN Messenger
Stevo02TJ
PostPosted: Sun Jan 30, 2005 9:35 pm    Post subject: Reply with quote
I didn't have a problem like this, I don't know of a site that could help you....most replacement antenas out of an aftermarket parts catalog are for 76-95 CJs & Wranglers.
I would try your local junkyard for starters. thumbs [/url]
CoreyXJ
Turkish
Turkish
PostPosted: Sun Jan 30, 2005 10:46 pm    Post subject: Reply with quote
TJFreak-
I used to work on these type of Jeeps all the time. Many of the Jeeps that were going to be sold as "service" type Jeeps or to the government came with no radio and no antenna. Heck a lot of them didn't even have speakers in them!!!
You can go to an Auto Electronics retailer and buy the antenna with an extension piece to get you up behind the dash. OR you can go to the stealership and order one in for about a million dollars....
Installing it is very easy. There should be a spot on the passenger side fender that is set aside for the antenna. Its going to have to be drilled so break out the drill and a good size bit. You want to drill a hole big enough for the antenna wire to fit through, and then 4 small ones to match up to the holes that are already in the antenna base. You may take a look at another TJ just so you can get an idea of what to do. Very simple and shouldn't take too long.
CoreyXJ
TJfreak
PostPosted: Mon Jan 31, 2005 6:30 am    Post subject: Reply with quote
Why would 97 Wranglers be made for that?
CoreyXJ
Turkish
Turkish
PostPosted: Mon Jan 31, 2005 9:33 am    Post subject: Reply with quote
Beats the heck out of me - All I know is that I have worked on several of them ?!?!?
Most of them were 5spd 4cyl no A/C and very plain....
CoreyXJ
PostPosted: Mon Jan 31, 2005 10:10 am    Post subject: Reply with quote
Probably some utility companies used them - I know one of the local water districts fad a few.
'drack
▲▼webwheeler▼▲
▲▼webwheeler▼▲
PostPosted: Mon Jan 31, 2005 1:18 pm    Post subject: Reply with quote
I bought my old '97 new off the lot. I wanted a bare bones model, so the only options I got were the rear seat/carpet combo. I opted not to get the factory radio since I had an aftermarket head unit I was gonna install. The Jeep had no radio, speakers, or antenna but did have all the wiring present so it was a plug in job afterwards. Not sure what year radios became standard equipment on SE's, but I can confirm that it wasn't in '97....so it's nothing outta the ordinary to have Mr. Green .
Oh yeah, I ordered my antenna kit from Leon Rosser. Came with the wiring, mast, base, etc. Complete factory setup.
Drink more Ovaltine!!!
SNOFRK
PostPosted: Thu Feb 03, 2005 6:38 pm    Post subject: Reply with quote
30 bucks and you can have a stock setup...... got to jeepsareus.com
http://www.jeepsareus.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=JAU&Product_Code=Anteniapkg&Category_Code=Wrangler2
01 TJ locked loaded and fires for effect!!!
TJfreak
PostPosted: Thu Feb 03, 2005 8:27 pm    Post subject: Reply with quote
http://www.jeepsareus.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=JAU&Product_Code=MAS&Category_Code=Wrangler2
Why does it say "Wrangler Cherokee 1997-2001" ?? They are including both the Wrangler and Cherokee years together I guess???
PostPosted: Thu Feb 03, 2005 10:37 pm    Post subject: Reply with quote
It's probably their way of simplifying their site. It looks like when you order, you have a choice of several models.
PostPosted: Thu Feb 03, 2005 11:17 pm    Post subject: Reply with quote
Yup, they do it that way because it's 2 less entries in the form, simplifing it. 97 was a redesign year for both models: Wranglers went from YJ's to TJ's and Cherokees had the whole "body redesign" thingamajig.
