overdrive not working and center console display quit workin
dh2000dh
PostPosted: Sun Feb 13, 2005 1:37 pm    Post subject: overdrive not working and center console display quit workin Reply with quote
two seperate problems.
1. won't shift into overdrive. Used to be that it needed to travel 10 miles on interstate, then would shift into overdrive, but now it's not shifting into OD at all.
2. Center console display started flashing went out.
Now it's not coming on axcept to at random times,Beep, Beep and flash "Coolant low" and "washer level low", then goes off again.
Any help would be appreciated
David
PostPosted: Sun Feb 13, 2005 3:04 pm    Post subject: Reply with quote
Take off the center radio surround thingy and check the plugs ... Make sure you are plugged in good.. Might want to pick up some electrical contact cleaner..
As for Overdrive start by flushing your tranny and putting new fluid in..
Then while you are under there check the plugs on the tranny and make sure the OVerdrive off button is not pushed or broken...
Let me know if you dont know how to flush the tranny I will help you out ...
Carl
PostPosted: Sun Feb 13, 2005 5:16 pm    Post subject: Reply with quote
year? dad works on mopar stuff...overheard him sayin that the jeeps with the center consoles had all kinds of bugs till about 96-98
