Novak Conversions Universal Transfer Case Shifter
PostPosted: Mon Feb 14, 2005 11:30 am    Post subject: Novak Conversions Universal Transfer Case Shifter Reply with quote
Novak Conversions has announced the release of a universal transfer case shifter for Jeeps called the SK2X Shifter Assembly. Designed for YJ & TJ Wranglers, to XJ, MJ and ZJ Jeeps, the shifter replaces everything from the shift plate at the transfer case, right up to the shifter knob in the driver’s hand - in all of these Jeeps. It will shift the 207, 231 (four position) and 242 (five position) transfer cases, as well as 4:1 low conversion cases, and units with aftermarket “2 Low” shift plates.
Full Article and Photos
PostPosted: Mon Feb 14, 2005 1:47 pm    Post subject: Reply with quote
I was looking at this a few days ago.. looks nice and if you download the instructions it tells you how to build your own... Mr. Green
