plastic flex tubing
little Army guy
PostPosted: Wed Feb 16, 2005 1:58 pm    Post subject: plastic flex tubing Reply with quote
this weekend I added mini off-road lights to my TJ's roof rack, thing is I can't find any metallic/steel flex tubing to protect the wiring that runs from the inside to the lights. Can I use the black plastic tubing that is typically seen in engine compartments and under dashboards? or will this it crack/dry rot soon? If you think I should use metallic/steel tubing, where can I get some? I went online and the search engine weren't doing me justice. THANKS.
Ray
PostPosted: Wed Feb 16, 2005 4:18 pm    Post subject: Reply with quote
Plastic split loom will be fine. It's used all over vehicles without a problem. Steel would be overkill and rust anyway.
little Army guy
PostPosted: Thu Feb 17, 2005 5:19 pm    Post subject: Reply with quote
you guys are like big brothers. you have answers for everything! thanks.
Ray
