97 TJ I-4
JeepTJKID
PostPosted: Fri Feb 18, 2005 7:17 pm    Post subject: 97 TJ I-4 Reply with quote
Hey, Im new and i own a 97 Jeep wrangler, its has a I-4 engine and is an auto tranny. Would i be able to do some mudding with this engine and the auto tranny? Also i am considering a RE RE7002 3.5" Standard Kit TJ - The Standard kit is a perfect entry for those looking to run 33" tires on a smaller budget. The 3.5" Standard kit includes springs, and bump stops, but maintains stock control arms and track bars. On and off road performance of this kit is excellent and is easily upgradeable to the Super-Flex kit by adding our control arms and other Super-Flex components. What else would i need for this lift to work properly. Do i have to do ne modifications to make this lift fit, lower nething, extend nething?
Also what kind of accesories would u suggest to get for mudding and slight off roading.
PostPosted: Fri Feb 18, 2005 7:24 pm    Post subject: Reply with quote
since you have a 4 banget and you want 33s id re gear other than that you may need brake line extension and maybe a t case drop kit and for a budget id get some tires that are road friendly like stevos bfg a/ts i have buckshots and i like them all tho mud tires dont last long on the road
