transfer case swap
c-mike-go
PostPosted: Fri Feb 25, 2005 1:50 pm    Post subject: transfer case swap Reply with quote
I have a 2000 XJ with the Command-Trac (part-time 4WD) transfer case. Is it possible to drop in a Selec-Trac (full-time) xfer case, or do additional changes have to be made ? Any idea on approx. prices for a used case ? I think it's the NP 242.
PostPosted: Wed Mar 02, 2005 2:00 am    Post subject: Re: transfer case swap Reply with quote
It is the NP242...that's the t-case with the full time option. It should be a direct bolt on. The only exception might be with the driveshaft, depending on the donor XJ it comes out of (year, rear axle type, etc.).
I have no idea what a boneyard would charge for one.
