Dash speedo, tach, gas guage problem. Short or ground?
ronpapworth
PostPosted: Mon Feb 28, 2005 7:55 am    Post subject: Dash speedo, tach, gas guage problem. Short or ground? Reply with quote
Hi all,
My 95 cherokee just started having problems with the dash. Seems something is loose under there. The Tach, Speedo and Fuel guage all jump to life and die together, other guages are fine. I am thinking this is a short in the power or maybe a ground problem. I searched and didn't see this specific problem so I am hoping there may be a write up on this fix? Or just let me know what component might be suspect and it's location and I can go searching.
Thanks all!
Ron
CoreyXJ
Turkish
Turkish
PostPosted: Mon Feb 28, 2005 10:45 am    Post subject: Reply with quote
Have you gotten water in and/or around the dash cluster recently ???
ronpapworth
PostPosted: Mon Feb 28, 2005 1:28 pm    Post subject: Nope Reply with quote
Not that I know of, unless the windshield seal is failing. But no water has fallen on my feet!
PostPosted: Wed Mar 02, 2005 1:49 am    Post subject: Reply with quote
There is a TSB on this...No.08-15-99. The solution is to replace the Instrument Cluster wiring connector. This part number is 05016261AA and it's pretty cheap...under $10, but requires some soldering. This procedure takes around an hour and that includes pulling the instrument cluster.
Since it could also be a bad ground, while you are in there clean all the terminals/pins and put some dielectric grease on them. That should fix 'er up.
HTH
Steve
ronpapworth
PostPosted: Wed Mar 02, 2005 7:23 am    Post subject: Thanks! Reply with quote
Wow. Great stuff. Ill order the part now!
Ron
ronpapworth
PostPosted: Mon Mar 21, 2005 12:10 pm    Post subject: Different dash? Reply with quote
Well I got that part and pulled the dash apart. My connector is different than the part number listed. There were two connectors running into the back of the cluster, one for the warning light side of the cluset and another that I am assuming is for the rest of the guages. Has anyone ever seen a different clip on the back? Other than the ground at the back of the valve cover, are there others that could trip this?
