1996 gr.cherokee ltd.ed. Rad. Flush
gonzopg73
PostPosted: Thu Mar 10, 2005 4:08 pm    Post subject: 1996 gr.cherokee ltd.ed. Rad. Flush Reply with quote
Hello, hoping somebody can help with this question. I have a 96 grand cherokee Ltd. Edition and went to flush the radiator but found out that there's no cap? found the spicket to release the fluid but where do i replace the fluid through? also, am I supposed to bleed the air out of the system as well? and how do i do that? hope you can help. Shocked
PostPosted: Fri Mar 11, 2005 5:38 pm    Post subject: Reply with quote
???????????? No radiator cap??????????
Get me a pic of the engine.. .There must be something...
As for getting the air out I usually just fill it with water then start her up.. Let it run til the thermostat opens and then put more water in.. IT will eventually burp...
I have the Radiator out of a 98 in my grand and it had a rad cap... I have never seen one without one....
I guess if you had to you could just pull the upper hose off and fill it there till it came out the Thermostat houseing.. Neutral
