Transfer case oil change . . .
rammons
PostPosted: Fri Mar 25, 2005 11:43 am    Post subject: Reply with quote
Once again, you guys ROCK! I did find the tag (my mind told me it would look different so I missed it) it was painted black so I missed it last night in the dark. I do not have the Locking diff. Going out to do the fluid change right now. I'll write back and let you know how it went!
Thanks again,
Bob
Bob Ammons
2000 Yellow TJ
PostPosted: Fri Mar 25, 2005 11:57 am    Post subject: Reply with quote
You'll do fine and be sure to get all the old gasket material cleaned off the mating surfaces. Wink
rammons
PostPosted: Fri Mar 25, 2005 7:31 pm    Post subject: Reply with quote
Well, I managed to get the covers of the diffs (thanks for the rubber hammer trick), but getting the old gasket material off was a pain in the butt! It took hours for me to get that stuff off, and I'm not entirely sure I got it all off (especially on the rear diff).
The transfer case was easy as pie, just as you said it would be (thanks). I do have somewhat of a mess in the skid plate, but I'll wash that off at a car wash or something.
I haven't filled the diffs yet because I got tired of scraping old RTV off and I ran out of time. I'll fill them tomorrow night and see what happens. At least the RTV will be completely cured by then.
I found out I need a new radiator too. Noticed a leak while I was working on the front diff.
Thanks again for all your help and I look forward to being able to do more work on the Jeep!
Bob Very Happy
Bob Ammons
2000 Yellow TJ
PostPosted: Fri Mar 25, 2005 8:56 pm    Post subject: Reply with quote
You can use a plastic scraper like the one in the picture along with some brake or carb cleaner. I'm not sure the exact name of it, but it's about a buck and made for body work.
