Daytime Driving Lights
skidmark
PostPosted: Wed Mar 23, 2005 7:27 am    Post subject: Daytime Driving Lights Reply with quote
Can someone tell me if there is a way to disconnect the daytime driving lights on a 92 YJ?
ANYONE??????????
Thanks Neutral
Black 92 YJ, 33" MT's, 4.0 HO, 4.88's, Warn HS9500, Aussie Locker in Front, Lots More on the Way.
shvlhd666
PostPosted: Sun Jul 17, 2005 8:16 pm    Post subject: Reply with quote
Was your YJ originally from Canada?
You will have to get a wiring diagram for your particular year.
My 95 YJ manual indicates that only vehicles intended for Canada have the daytime running lights. Anyway, my manual shows a "Daytime Running Lamp Module located on the drivers side fender well. There should be an 18 guage black wire going to a common ground and 16 guage light green wire with a white tracer going to the dimmer switch. I suppose you could try disconnecting the LG/WT wire and see what happens. After reading the manual a little more, it may not be that easy. But give it a try.
skidmark
PostPosted: Tue Jul 19, 2005 3:54 pm    Post subject: Reply with quote
Yes it was built in Canada. Thanks for the info, I will try it.
nikon
PostPosted: Sat Jul 23, 2005 12:14 pm    Post subject: Reply with quote
well I think that you've found your problem right there....eh
LISTEN TO BLACK SABBATH
FM2CDJC Member #10
9. Thou shalt not kill. Unless some motherf****r is coming into your house to take your s**t! - The Nuge
