Differential noise when turning slowly
drlgrandcherokee
PostPosted: Mon Apr 04, 2005 8:03 am    Post subject: Differential noise when turning slowly Reply with quote
I had a left rear seal leaking, had seal bearing replaced and new oil added to differential, there was no noise coming from rear end until after all this work was done ??, it sounds like gears rubbing together with no oil ,I think they did not put in enough lube or the additive, when driving down street or turning a corner.
Can this be the problem ??, not enough oil ?
Brad S
PostPosted: Mon Apr 04, 2005 10:28 am    Post subject: Reply with quote
check it?? Confused
drlgrandcherokee
PostPosted: Mon Apr 04, 2005 10:54 am    Post subject: Reply with quote
I have it bajavascript:emoticon('Neutral')
Neutralck at the no reliable repair shop, that did the seal Friday
drlgrandcherokee
PostPosted: Mon Apr 04, 2005 10:55 am    Post subject: Reply with quote
Woops, I have it back at the repair shop that did the work friday, I figured since they had there hands on and it is a nationalu known repair place.
drlgrandcherokee
PostPosted: Mon Apr 04, 2005 10:57 am    Post subject: Reply with quote
Can't wait to hear the story from them.
