Has anyone put a transmission cooler on before?
chapsxj
PostPosted: Sun Apr 17, 2005 2:23 pm    Post subject: Has anyone put a transmission cooler on before? Reply with quote
I am planning on using my XJ to haul a couple of 4 wheelers(3 to 4) around on the weekends and with a larger wheel/tire combo I want to add a cooler to help the transmission out? Has anyone done this? Do you have to drill a hole for the fluid lines? If so where?
PostPosted: Sun Apr 17, 2005 2:56 pm    Post subject: Reply with quote
I've installed quite a few of them over the years. Most recently, last fall on the XJ. You do not have to drill holes. Shocked
All you are doing is adding a secondary cooler to the one already built into the radiator. Usually, the coolers come with pretty detailed directions, but it's simply a matter of installing it inline with the transmission feed sending fluid to the existing cooler.
There's a section in this writeup on the install I did. http://jeephorizons.com/phpbb/viewtopic.php?t=3203
