whinig noise...tranny or transfer?
xXjeepaholicXx
PostPosted: Wed Apr 27, 2005 6:03 pm    Post subject: whinig noise...tranny or transfer? Reply with quote
i have a whining noise coming from my tj that has a grinding/clicking noise in with it. it does it only when accellerating and the faster you go the worse it gets. i have 4..88 gears put in 3 weeks ago. the dude that put them in said they arent the problem. he said wither transfer case or tranny is the problem. the pin that goes through the spyder gears in the rear has slop in it that you can feel when you first let off the clutch. could that be it? pleeeease help me with your input on the problem thanks a million
yeeea
PostPosted: Thu Apr 28, 2005 4:10 am    Post subject: Reply with quote
You should probably replace the guide pin if there's slop in it. Also, check your u-joints. With the 4.88s, the driveshaft is now spinning faster and your u-joints may be on the way out.
