cherokee engine problem
kkerem
PostPosted: Wed May 25, 2005 1:14 am    Post subject: cherokee engine problem Reply with quote
Hi all.
First Im sorry, Im not native english speaker...
I have 1989 cherokee (AT/AC) 4.0.
It has some mysterious engine problem. When I start the engine it takes about 10-20 seconds. When it idles then one or two cylinder will fail I think, anyway it is choppy. When Iím accelerating slowly the engine fails, when I do it extra slow the engine fails completely (shuts off). When Iím driving at solid speed the engine runs, but after some time it goes choppy again. When Iím accelerating very strongly (pressing the pedal to the floor), then the engine ďthinksĒ a moment and runs well. Acceleration is normal and the engine has the power.
So I have changed wires, fuel filters, spark plugs, MAP sensor. But the engine still has the same problem(s).
I suspect that on problem can be in fuel pump and/or vacuum lines. Also I found one resistor, in under hood (driver side).
So my question is what may cause the problems? Also does anyone have a vacuum diagram? Does anyone know how big the fuel pressure should be?
Thank You
Sammy Crash
PostPosted: Thu May 26, 2005 12:51 pm    Post subject: Reply with quote
You really should post this in the Cherokee forume, they'll be able to help more on that than us CJ guys and gals Wink
PostPosted: Thu May 26, 2005 10:23 pm    Post subject: Reply with quote
Moving this for you. Wink
MachineMan
PostPosted: Mon May 30, 2005 12:34 pm    Post subject: Reply with quote
I have 1990 and it also takes 10+sec to start while cranking. From what I've heard its normal becuase the computer is initailizing stuff prior.
If your idle is messed up check your EGR valve. It might be leaking exhuast into the intake at idle. Its only suppossed to at higher RPM's.
PostPosted: Tue May 31, 2005 9:00 am    Post subject: Reply with quote
cherokees do take longer to crank but shouldnt take 10+ seconds my guess would more in the neighbor hood of 3-5 as my father and friend has a cherokee and thats how long it takes for them to fire
check your sensors had a vehicle that the o2 sensor was bad and it would stall cough and sputter
