1995 Cherokee quit while going down the highway.
ptrollen
PostPosted: Wed May 11, 2005 5:57 am    Post subject: 1995 Cherokee quit while going down the highway. Reply with quote
Being an old school mechanic, these computer control jobs stump me...
I have a 1995 Country 4.0 AT. I was driving down the highway & it quit. It also made a wierd "POP". I had on the AC , maybe the clutch..? No Spark & A scan tool says " Vehicle not responding" (I believe they have to be running for scan tool to work..) Coil has 12v, Replaced p.u. coil, checked most sensors (unable to check CPS due to no wire letters on the plugs). This happened a couple days after a oil change, tune up, 160 t-stat. Now just cranks over. Dist. spins. Any suggestions?
PostPosted: Wed May 11, 2005 7:10 am    Post subject: Reply with quote
The ECM should give you error codes even if the engine is not running. Try the key trick and see if you get any codes back. The '95 is an OBDI system, so those are the codes you'll get back. Post 'em up and we'll take it from there.
I'm an old school (backyard) mechanic too...leaning about the computer control is a necessary evil these days. Wink
ptrollen
PostPosted: Wed May 11, 2005 9:53 am    Post subject: Reply with quote
Thank you, I'm on step one now...
I got a 12 & 55 codes, checked it 4 times..
12 is power disconected (when I switched computers to check)
55 is end of sequence..
what now?
ptrollen
PostPosted: Fri May 13, 2005 6:53 am    Post subject: Final Reply with quote
I just got my cherokee a month ago, lost spark so I searched the Inet like many others...... so for everyone out there take this advise: If you do not have spark REPLACE THE CRANK POSITION SENSOR FIRST.
Peace to all..
* Turn in all Meth Heads you are aware of.
* Terrorists are fags.
* It's better to do right than be right.
