04 Rubicon diff and tranny fluid capacities
RubiRock
PostPosted: Mon May 16, 2005 7:01 pm    Post subject: 04 Rubicon diff and tranny fluid capacities Reply with quote
i've got an 04 rubi with the 5spd tranny and i've been trying to find the fluid capacities for the dana 44s, transfer case, and manual tranny. havent found anything in the owner's manual or jeep owner's bible that tells me specifically and I havent found a haynes or chilton manual that is updated with the rubi's specs. i'm planning on ordering RedLine MT90 for the tranny and 75w90 gear oil for the diffs (has friction modifiers for the lsds) but i need to know how much of each i should get. should i go with mopar instead? i've never heard a complaint from those using redline.
anyways, any help would be greatly appreciated. and if anyone has a cheap/free source for a factory service manual, i'd really like that.
thanks
imran
PostPosted: Tue May 17, 2005 1:12 pm    Post subject: Reply with quote
Capacities, per the 2003 TJ FSM
FLUID CAPACITIES
FUEL TANK 19 U.S. Gallons (71.9 Liters)****
ENGINE OIL
Engine Oil - with Filter - 2.4L
3.8 L (4.0 qts.)
Engine Oil - with Filter - 4.0L
5.7 L (6.0 qts.)
ENGINE COOLANT
Cooling System - 2.4 L 8.5 L (9.0 qts.)
Cooling System - 4.0 L 9.9 L (10.5 qts.)
POWER STEERING SYSTEM
Power steering fluid capacities are dependent on engine/chassis options as well as steering gear/cooler options. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an
auxiliary cooler, these capacities may vary. Refer to 19, Steering for proper fill and bleed procedures.
AUTOMATIC TRANSMISSION
Service Fill - 42RLE 3.8 L (8.0 pts)
O-haul Fill - 42RLE 8.3 L (17.6 pts.)
Dry fill capacity Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these figures may vary. (Refer to 21 - TRANSMISSION/AUTOMATIC - 42RLE/FLUID -
STANDARD PROCEDURE)
TRANSFER CASE
NV231 1.0 L (2.2 pts.)
NV241 2.0 L (4.2 pts.)
MANUAL TRANSMISSION
NV1500 Approximate dry fill or fill to bottom edge of the fill plug hole.
2.3 L (4.8 pts.)
NV3550 Approximate dry fill or fill to bottom edge of fill plug hole.
1.98 L (4.2 pts.)
FRONT AXLE .03 L (1 oz.)
181 FBI (Model 30) 1.2 L (2.5 pts.)
216 RBI (Model 44) 1.89 L (4.0 pts.)
REAR AXLE .03 L (1 oz.)
194 RBI (Model 35) 1.66 L (3.5 pts.)*
216 RBI (Model 44) 1.89 L (4.0 pts.)*
* With Trac-lok add 118 ml (4.0 oz.) of Limited Slip Additive.
****Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
RubiRock
PostPosted: Tue May 17, 2005 1:32 pm    Post subject: Reply with quote
thanks ehirner!!! exactly what i needed to know.
WhatWasIThinkin
PostPosted: Tue May 17, 2005 5:46 pm    Post subject: Reply with quote
Redline or Amsoil are both great products. Mopar is fine but costs WAY TOO MUCH. Last I new Mopars synth fluids were @ $32 a quart from the stealership.
I beleive that the Rubes still require 75w135 or 90w135 gear oil......its on the tags on the diffs...I dont remember exactly which it was.
Real Jeeps dont wear Bra's
