rough idle
pedanticfish
PostPosted: Tue May 17, 2005 1:38 pm    Post subject: rough idle Reply with quote
my 90 Cherokee has an erratic idle a lot of the time. It'll wander between 200 and 400 rpms most of the time I'm stopped. I've noticed that if I drive with a heavy foot the idle will even out at around 600. I don't have any money so I'd like to fix it myself before taking it to a shop. Any help would be great thanks.
MachineMan
PostPosted: Tue May 17, 2005 2:56 pm    Post subject: Reply with quote
Check all the vacuum lines.
My '90 was idling low when my MAP sensor vacuum line had a crack in it.
Here's some pics of vacuum lines on a '90..
http://www.4x4trailhunters.com/article.php?id=16
pedanticfish
PostPosted: Wed May 18, 2005 9:07 pm    Post subject: Reply with quote
i checked all the vacuum lines they seem fine. if the map is broken how can I check it?
