Fitting a CB antenna to an XJ
cartman
PostPosted: Wed May 18, 2005 1:09 am    Post subject: Fitting a CB antenna to an XJ Reply with quote
Now other than boring a hole through the roof or fitting a mag mount, neither of which I want to do, where have you managed to fit an antenna?
Either a gutter mount or boot lip mount would be my preference but which type have you used. And have you found it to be up to the job?
Cheers, Paul Shocked
PostPosted: Wed May 18, 2005 4:05 am    Post subject: Reply with quote
I have a bracket in the rear of my XJ that is unobtrusive when I close the rear hatch door. It sticks out to the right-side rear of my Jeep and allows for a Firestik II to be attached. It has four mounting holes that you have to drill into the frame, but the mount is not visible with the hatch down.
I run the CB cable under the molding inside the Jeep all the way to the front part of the cab where my radio is. It's a pretty good setup, and is stable for offroad applications.
CoreyXJ
Turkish
Turkish
PostPosted: Wed May 18, 2005 8:26 am    Post subject: Reply with quote
http://jeephorizons.com/tech/xjcb.html
cartman
PostPosted: Thu May 19, 2005 2:17 am    Post subject: Reply with quote
As I said above. I want to go away from mag mount and drilling though the bodywork. Over here you drill a hole through steel and the corrosion starts immediately Sad Mag mounts get knocked off by low 'flying trees'.
Ordered the bits today and I'm going with a hatchback mount on the rear hatch. Adjustable in all directions to get the right attitude. Then to stick the whip on and see how it goes Razz
Cheers all.
