4 Hi won't come out???
zimflux
PostPosted: Thu May 19, 2005 8:29 am    Post subject: 4 Hi won't come out??? Reply with quote
My brother took his 01 XJ to the dealer b/c he could not shift out of 4-wheel drive with out playing with it for a while. The dealer stated that one of the front tires is newer than the other and will cause the transfer case not to disengage. This is total bs right??
PostPosted: Thu May 19, 2005 8:33 am    Post subject: Reply with quote
Sounds like a line to me. Wink
Is it stock? Is there a transfer case drop that might be causing the shifter to bind?
zimflux
PostPosted: Thu May 19, 2005 8:40 am    Post subject: Reply with quote
Which line are you talking about?
Thank you
PostPosted: Thu May 19, 2005 8:43 am    Post subject: Reply with quote
The line of BS about the tires. Wink
zimflux
PostPosted: Thu May 19, 2005 8:51 am    Post subject: Reply with quote
lol funny... yeas thats what I thought.
The Jeep is stock. I might have to get under and check the fluid. My brother stated that he could put place the XJ in 4hi but it was hard to get out. I belive he tried going baclk and forth till it did go back to 2 wheel drive. Any ideas? Thx
