Fuel Pump
kygreenyj
PostPosted: Fri Jun 03, 2005 8:54 am    Post subject: Fuel Pump Reply with quote
My brothers XJ died the other day and the stealership said it was the fuel pump, and they want $600 P&L sorry i can;t give more info, but i'm 250 miles away. Does that sound right as far as the price? where is the fuel pump down in the tank> or somewhere else? thanks
06 Ford Escape Hybrid
03 KLR 650
majikxms
PostPosted: Fri Jun 03, 2005 9:58 am    Post subject: Reply with quote
What year is it? In 98+ they are on top of the tank and you'll need to drop the tank to get to it. So is the filter. $600 is a bit steep, but that is from the stealership.
Farmer Dean
PostPosted: Fri Jun 03, 2005 10:02 am    Post subject: Reply with quote
The pump is in the tank. You have to drop the tank to get to the top of the tank where you access the pump. It's not a hard job, but if your brother is not mechanically inclined, then a dealer is the only choice. Factory fuel pumps are very expensive. An after market one is about a third the price. $600 for the dealer to put in a factory pump seems about right. If you can do it yourself count on a couple of hours and a hundred bucks. If you're going to try it yourself, let me know and I'll walk you through it. FD.
kygreenyj
PostPosted: Fri Jun 03, 2005 12:10 pm    Post subject: Reply with quote
its a 95 6cyl i wonder if it would be pissible to do a fix like carls on an xj??
03 KLR 650
