cruise control and air condition vent swith not working
wtweathers
PostPosted: Thu Jun 09, 2005 5:05 pm    Post subject: cruise control and air condition vent swith not working Reply with quote
I have a 1999 grand cherokee laredo 4X4. The other day, my cruise control quit working, and my AC/Heater fan started only blowing out of the defrost port no matter if I have it set on face, feet or defrost. The AC still works fine, but only blows out of the defroster port. Are these two things running through a fuse that may have blown, or are my problems bigger than that? Thanks to anyone that can help!
wtweathers
PostPosted: Fri Jun 10, 2005 3:16 pm    Post subject: Reply with quote
Vacuum line... Look around under the battery box and on the passenger fire wall.. It will be easy to find it if you have the engine running ... You should be able to hear the hiss...
The line that runs into the passenger fire wall will be a small hard plastic line and it is known to break rendering your Blend door functionless..
Good luck..
Carl
