2000 GC leaking water frm firewall-engine side
rhr0812
PostPosted: Mon Jun 13, 2005 9:07 am    Post subject: 2000 GC leaking water frm firewall-engine side Reply with quote
I have noticed that water is leaking (1/2 pint) from the housing with a little stub that is built into the firewall. Its right under the 2 heater hose connections and is a permnanent tube built into the wall. Does anybody know what this is or where the water is could be coming from.
95sahara
PostPosted: Mon Jun 13, 2005 2:22 pm    Post subject: Reply with quote
I bet you've already checked, but is the water hot, or smell like antifreeze? Cause if it does, then it's a safe bet that it's leaking out of the heater hoses. But if it's just rainwater, then lay down on the seat and look under the dash while someone sprays the Jeep with a garden hose, then stop the leak whereever it is.
06 Rubicon
4" RC sus. lift, 1" PA BL
PICS
PostPosted: Mon Jun 13, 2005 6:38 pm    Post subject: Reply with quote
Sounds like the Drain for the airconditioner evaporator.. It is supposed to leak water it means the air conditioner is removing moisture from the air..
If it stops leaking .......Worry... Mr. Green
95sahara
PostPosted: Mon Jun 13, 2005 7:08 pm    Post subject: Reply with quote
Oh geez, I thought he was talking about water leaking INTO the Jeep. My bad.
06 Rubicon
PICS
quadna71
PostPosted: Tue Jun 14, 2005 5:04 am    Post subject: Reply with quote
swampy's right. mine was dripping plenty of water - but when driving at speed the air would push the water back in and make it run into the jeep. i put a 90* elbow and short section of tubing on it and have it running down around 6"....no more wet floor in the jeep now Smile
chris
2003 TJ Sport
