225 c.i. v-6
tudor
PostPosted: Sun Feb 27, 2005 4:38 pm    Post subject: 225 c.i. v-6 Reply with quote
Wink greetings, i'm a newbie on forum, does anyone have any practicle knowledge on a 1969 cj 225 c.i. engine ? my question has to do with wether i should buy this 69 cj with 225 eng. are most parts still available for the motor to keep her running ? was this a decent reliable performer ? should i forget it and look to buy a newer jeep because of parts availability? how about the axels-transfer case that came stock on the 69's any opinions on reliability thank you appreciate any info.thanks Wink
Tardis
PostPosted: Wed Mar 23, 2005 10:57 pm    Post subject: Re: 225 c.i. v-6 Reply with quote
225 V-6's are AMC/Buick motors. It's basically an early version of an odd fire 231. They run about as good as 231's do. Parts are still available, and if you don't like the 225 put a 304 in it. That year Jeep should have the good Dana front axle with the cup style steering joints. Those axles are pretty tough. If you can pick the Jeep up for a reasonable price then go for it.
98' TJ, 99' XJ
bloodwood70
PostPosted: Fri Jun 10, 2005 11:37 am    Post subject: 225 odd fire Reply with quote
this engine is a real good engine for the older jeeps
for the weight and horses good engine
I have a 53 cj3a I am putting one into
the 225 has 160 hp at 4000 rpm with mid to high 200's ft lbs of torque
timing is the only issue with these engines
a huge plus is a stronger crank than the even fires
with a 50 or 75 lb flywheel these will idle over obsticles nicely
