Pitman Arm
bgreiwe
PostPosted: Sat Jun 18, 2005 8:44 pm    Post subject: Pitman Arm Reply with quote
While trying to install my new power steering box in my TJ, I came to a major problem. I was able to disconnect everything I needed to but the pitman arm would not come off of the steering gear. I tried a pitman arm puller with a breaker bar but it just seperated, slipped down the side, and put a gouge in my pitman arm. I tried PB blaster to loosen it up if it was a little rusty. I could not think of other way to pull the arm off. Anyone have any suggestions as a way to loosen it up.
PostPosted: Sat Jun 18, 2005 8:51 pm    Post subject: Reply with quote
I used a puller and an impact wrench. After that didn't work, I used a breaker bar with the puller and just as I was ready to give up for the night, it ever so gently popped off. As I recall, it was a long bar and I braced myself on the axle for leverage. What seperated, the puller?
bgreiwe
PostPosted: Sun Jun 19, 2005 8:49 am    Post subject: Reply with quote
the two sides of the puller seperated and went around the pitman arm instead fo pulling it off.
PostPosted: Sun Jun 19, 2005 10:36 am    Post subject: Reply with quote
In that case, try a pickle fork?
hhassey
PostPosted: Fri Aug 26, 2005 4:07 pm    Post subject: Pitman Arm Reply with quote
I've heard that heating the pitman arm will make it expand and then you can easily pullit off with the puller.
Be carefull not to get yourself burn though!!!
oldcarguy
PostPosted: Tue Feb 28, 2006 9:37 am    Post subject: Reply with quote
putting tension on arm w/ puller and then smacking shaft w a heavy ball peen to "shock" it loose has always worked for me. be sure to leave nut on to end of shaft to protect threads, though.
