'93 YJ runnin' crappy
sidehill
PostPosted: Mon Jun 20, 2005 3:13 pm    Post subject: '93 YJ runnin' crappy Reply with quote
FNG so please be gentile. Fresh 02 sensor, plugs, wires ,rotor, cap, filters, ect. Rig has an intermittent stumble on acceleration, though it dosen't do it every time. A guy at work said something about pullin the throttle body & cleaning somethin' or other fixed his neighbors with similiar problems.
PostPosted: Sun Jul 17, 2005 9:55 am    Post subject: Reply with quote
You don't say what engine you have, but a lot of the steps in this article will be the same and give you an idea of what's involved.
http://www.links4jeeps.com/link.php?id=1193
sidehill
PostPosted: Tue Jul 19, 2005 1:27 am    Post subject: Reply with quote
Very helpful, thanks. Yeah I forgot to mention the 4.0 liter engine, duh!
The idle motor has tamper resistant torx fasteners so I just pulled the throttle body off & sprayed everything.
It still has a 1 second long sputter when I go to full thrittle but for everyday driving it's MUCH better.
sidehill
PostPosted: Fri Sep 09, 2005 10:05 pm    Post subject: Reply with quote
Well, I finally went to a real mechanic. The diagnosis? One of the plug wires I replaced two years ago was intermittently failing under load.
