TJ Brakes
obarno
PostPosted: Sat Jun 25, 2005 8:12 am    Post subject: TJ Brakes Reply with quote
Hi - I have just fitted a Terralow 4:1 transfer box to my 4.0 auto wrangler and find in low range even at tickover its difficult to hold against the brakes particularly in reverse. It has 4.1 diffs and 33" tyres and std. brakes. Whats the best way to upgrade the brakes - any advice greatfully received
PostPosted: Sat Jun 25, 2005 1:14 pm    Post subject: Reply with quote
This is one of the problems with an auto tranny, low gears, and the 4:1. Too much torque for the brakes to hold.
As far as upgrades, the Vanco Power Boost is highly recommended by members on another board. Also, look into the WJ knuckle swap. It uses stronger, dual piston calipers that work better than the standard TJ stuff.
obarno
PostPosted: Sun Jun 26, 2005 1:11 am    Post subject: Reply with quote
Thanks for your advice. I found the info on the Vanco product after I posted this and it seems like a good solution. I was also thinking about changing to rear discs but have heard that the parking brake is very poor unless you use Rubicon parts which are not generalyy available in the UK - do you have any experience of the after market kits?
PostPosted: Sun Jun 26, 2005 5:39 am    Post subject: Reply with quote
Rear discs won't be any better. The fronts do most of the stopping and rear discs don't have as much braking force as drums do. The advantage of discs is simpler maintenance and less brake fade during heavy use. Better braking is actually not one of their advantages if the rear drums are adjusted correctly.
obarno
PostPosted: Sun Jun 26, 2005 6:08 am    Post subject: Reply with quote
I didn't realise that - thanks for your advice.
