New Owner
sublime600
PostPosted: Sun Jun 26, 2005 9:56 pm    Post subject: New Owner Reply with quote
Hello i just bought a 2001 jeep cherokee and i have a few questions. One does anyone have the rattling in the cargo area when the vehicle is stopped. It sounds like it coming from underneath the jeep but when your in the front sounds like its the spare or something, very confusing. Also when u shoft it to drives the transmission shifts hard into drive. I was just wondering about theses things. Other than that I Love It.
PostPosted: Sun Jun 26, 2005 10:39 pm    Post subject: Reply with quote
rattling could be the exhaust my jeep did that turs out had a broken hanger and muffler was hitting the driveshaft
PostPosted: Mon Jun 27, 2005 12:32 am    Post subject: Reply with quote
Yep, check to make sure that everything is tight underneath. Also, I'm assuming it's an auto transmission? Has the fluid ever been changed? Is it at the proper level? Does it only do it when shifting into gear or when accelerating? Have you checked your driveshaft u-joint?
sublime600
PostPosted: Mon Jun 27, 2005 7:38 am    Post subject: Reply with quote
only does it when putting it in drive ill check the fluid today. Its under warranty so ill get them to check ou the exhaust thanks for help. Do you guys have any recommendations for tires. I was looking at yokohama geolander. Are they any good? Im looking for a good all road tire mostly street, and everyonce in a while dirt and stone. Thanks
PostPosted: Mon Jun 27, 2005 10:11 am    Post subject: Reply with quote
The exhaust is pretty easy to check yourself - just climb under and see if it moves when you try shaking it. Not sure what kind of weather you drive in, but I'm very happy with the ProComp AT's I have on my F250 - I'm at 40,000 miles on them and there's still quite a bit of tread left on them.
PostPosted: Mon Jun 27, 2005 9:06 pm    Post subject: Reply with quote
buckshot mudders i have 7k on them and they still look brand new i think they holind up well is because they are 8 ply instead of 6 265/75r16 are what i have which is about a 32x10.50 and they cost 100 bucks each i recommend them if you want a mud terrain
edit: sorry didnt see that last part
bfg all terrains
