How low can you go?
new2froadin
PostPosted: Thu Aug 11, 2005 7:09 am    Post subject: How low can you go? Reply with quote
Can someone tell me how low I should allow my TJ to go, during a water crossing, before I run the risk of having to rebuild my tranny?
Thanks
2000 Wrangler auto. d44 rear...4.88 detroit lockers front and back...Terra 4 to 1..Terra flex 4" lift 1"body lift...35" Meats
Onkover
PostPosted: Wed Oct 26, 2005 7:37 pm    Post subject: Reply with quote
Water crossings are vary dangerous. It can look shollow and end up real deep.
Best way for you to figure it out is to look for your breather tubes. Your front, rear axles, transfer case, and trans all hae a breather. Find them and trace them to the end. If it isn't high enough... raise them.
Also make sure where your engine air intake is. Sucking water into the engine SUX!!!
www.4x4trailhunters.com
