OBDII error 0720
Flintstone
PostPosted: Fri Jul 08, 2005 6:43 am    Post subject: OBDII error 0720 Reply with quote
"720 The Output Shaft Speed Sensor doesn't match the reported vehicle speed." What do I do with that to get the check engine lite out? Its a 98 Grand Cherokee with the 4L, auto, 4x4. I had just repleaced the catalytic converter when this came up and I wonder if its not something else because I changed the speed sensor and it changed nothing.
I also have the 55-75mph shimmy that I have read a bit about with suggections for checking u joints, steering stailizer, wheel bearings, anything else?
PostPosted: Fri Jul 08, 2005 7:05 am    Post subject: Reply with quote
Damn Computers....2
95sahara
PostPosted: Fri Jul 08, 2005 8:58 am    Post subject: Reply with quote
This means that your computer senses a difference between the speed that your ABS wheel speed sensors are reporting, and the speed that your speed sensor is reporting. This is assuming that you have ABS. There could be problems in other places, such as wiring, or other parts associated with the speed sensor circuit.
06 Rubicon
4" RC sus. lift, 1" PA BL
PICS
PostPosted: Fri Jul 08, 2005 5:05 pm    Post subject: Reply with quote
Or it could be mudd in the abs sensor.. (If you wheel that might be your problem.)
Assuming you do.. Take the tires off.. Clean the abs tone rings and sensors and see what happens..
Carl
