Removing Rear passanger window/lock unit
03Overland
PostPosted: Fri Jul 22, 2005 6:54 am    Post subject: Removing Rear passanger window/lock unit Reply with quote
Hello i have an '03 JGC Overland, i need to put a new keyless entry computer in.......
I have the part and it is built into the rear window/door lock assembly so all i need to do is just swap the switch panels assemblys out and get the unit proggramed
does anyone have a how to, or can anyone give me general overview as to how to get the switch panel out
does it just pop out? or do you have to take the dooor panel off, i haven't looked that closely, but i want to do it this weekend
thakns
PostPosted: Sat Jul 23, 2005 3:56 pm    Post subject: Reply with quote
All I know is that there is a torx (t 15 I think) screw in the door handle and some little plastic clips on the door panel.. (you will need a special tool for those ..)
Oh ...Yes you have to take the door panel off... Mr. Green
If you do a google on speaker replacement there will be a page that tells you how to take the door panel off..
03Overland
PostPosted: Mon Jul 25, 2005 6:21 am    Post subject: Reply with quote
Thank You sir
