Techie Dana 35c axle question...
hardyn
PostPosted: Thu Jul 28, 2005 12:34 pm    Post subject: Techie Dana 35c axle question... Reply with quote
does anybody have a drawing of the Dana35c axles?
specifically im looking for the dimension from the C-clip landing to the end of the axle "button"? we took apart my friends rear axle after much axle play, and we feel that the buttons are significantly worn, i have never seen anything like this, has anybody else?
if anybody has a known "good" axle they could measure that would be great... if you could meaure the in-board side of the c-clip landing to the end of the axle shaft that buts against the big pin the in differential carrier.
i suspect this distance should be approx 0.200" (the is a gross ball park)
thanks.
PostPosted: Thu Jul 28, 2005 6:50 pm    Post subject: Reply with quote
you could swap in the chrysler 8.25 found in the cherokees
its a bit stronger
hardyn
PostPosted: Fri Jul 29, 2005 10:29 am    Post subject: UPDATED WITH PICS Reply with quote
notice how the axles stubs are no where close to that big pin...
http://i6.photobucket.com/albums/y228/hardyn/3eb4bc8d.jpg
this is what im looking for...
http://i6.photobucket.com/albums/y228/hardyn/JeepYJDana35Axle.jpg
hardyn
PostPosted: Fri Jul 29, 2005 2:18 pm    Post subject: Found a number... Reply with quote
the boys at accu tec measured a new one for me
0.235"
Marisol141
Banned
PostPosted: Thu Dec 22, 2005 8:09 am    Post subject: A Tip Reply with quote
Think before you write. Thanks.
I'm a retard
