Error Code 2.4 (Throttle Position Sensor)
lawrence914
PostPosted: Mon Aug 29, 2005 2:56 pm    Post subject: Error Code 2.4 (Throttle Position Sensor) Reply with quote
First, thanks to everyone for previous advice. This place is awesome! Smile
Today, I had a check engine light on my 1998 TJ SE. Checked the error code, and got "2.4" which is:
'Throttle position sensor input above or below acceptable voltage. TPS signal does not correlate to MAP sensor."
Okay. What the heck does this tell me? TPS bad? Broken wire? (I looked and didn't see anything broken or loose.) Something else?
-Lawrence
P.S. While poking around, I found a broken exhaust manifold stud. Gonna have to take care of that when I get back from my business trip.
