how long does a bad drivetrain last?
fibulator
PostPosted: Sun Jul 31, 2005 3:18 am    Post subject: how long does a bad drivetrain last? Reply with quote
99 jgcl 4wd v8
theres a loud humming/whirring noise when i accelerate.
ive read that it could also be a differential, t-case, or some bearing problems.
Confused
________
FORD MODEL 91 PICTURE
95sahara
PostPosted: Sun Jul 31, 2005 6:26 am    Post subject: Reply with quote
That's your pinion bearing in the rear diff. My sister used to have a 99 also and it did the same thing. I've been told thats an extremely common problem on the early WJ's. She has an 02 now and it doesn't make any noise but we shall see what develops with more mileage (it's only got 30 some thousand on it now).
06 Rubicon
4" RC sus. lift, 1" PA BL
PICS
PostPosted: Sun Jul 31, 2005 7:57 am    Post subject: Reply with quote
Yup..Its probobly from the Aluminum 44 it gets worn over the years and starts making the humming noise.. I dont know how long it will last.. But it is not good. I also dont know if there is a way to fix it...
Can you or someone you know weld????
Your best bet would be to find a Ford Explorer axle and weld the brackets off the 44 onto it.. I have done it several times it takes me about 5 hours to do..
And you end up with a much stronger axle...
If you cannot weld.. Call some local welding shops and see if they can do it for you...
Good luck..
Carl
fibulator
PostPosted: Sun Jul 31, 2005 2:22 pm    Post subject: Reply with quote
no, unforunately, i dont know how to weld.
how much is an explorer axle?
________
Jeep Commander Specifications
PostPosted: Sun Jul 31, 2005 4:57 pm    Post subject: Reply with quote
Can be found for about $200 or so...
With 3:55, 3:73 and 4:11 as available ratios.
fibulator
PostPosted: Mon Aug 01, 2005 3:38 am    Post subject: Reply with quote
i called an ornamental welder yesterday for a quote, but he told me that he dont do "cars". Rolling Eyes but he said he was gonna ask one of his welder buddies to give me a call, but he didnt call me back. :[
________
Motor company of new zealand
PostPosted: Mon Aug 01, 2005 7:32 am    Post subject: Reply with quote
Would you really want an ornamental welder to work on your axle? I mean, even if he got the work done, you might get it back with hearts welded on or rod iron decerative pieces. shock
fibulator
PostPosted: Thu Aug 04, 2005 3:10 am    Post subject: Reply with quote
according to 95sahara a pinion bearing is messed up in my rear diff.
so i looked up a website to find me the parts i need to replace that pinion. so what do i need to order to fix the noise?
http://www.jeep4x4center.com/grand_cherokee/RearAxleModel44WJ.htm
and i also found this @ autozone http://www.autozone.com/servlet/UiBroker/?UseCase=C001&UserAction=answerRequiredQuestion&Parameters=%7C%7EDANA%2FSPICER+44+AXLE&PageSync=6
and heres a screenshot of the link above in case it dont werk.
________
VAPIR NO2
Venomized
PostPosted: Fri Aug 05, 2005 7:23 pm    Post subject: Reply with quote
If you have to ask what parts you need then my guess is you are not certain how to repair it either. This would be best left to a professional then.
1998 ZJ, some stuff
2001 WJ, not much stuff
fibulator
PostPosted: Sat Aug 06, 2005 2:04 am    Post subject: Reply with quote
if i had the luxury of being able to afford professional help, i wouldnt have to waste days upon days reading smart-assed comments like yours.
________
Gm foods
Venomized
PostPosted: Sat Aug 06, 2005 6:05 am    Post subject: Reply with quote
My comment was never intended to be smart-assed. Have you read on how to do the repair yet? Do you even know what the problem really is? All you know from what you have placed in your posts is that someone told you that they thought it was the pinion bearing. So now you open the diff and successfully replace the pinion bearing and put it back together and the noise is still there. Now you are out more $$ to fix it again and maybe even an entire new axle.
The diff is one areas IMO that you gotta know what the hell you are doing. I have only been that deep inside a diff 2X and both were with a friend that repairs for a living. I still won't attempt it myself either.
Find someone who knows what they are doing with differentials and have them help you with the diagnosis and repairs. Diagnosing noises over the internet is impossible.
1998 ZJ, some stuff
bmeyst
PostPosted: Tue Nov 29, 2005 4:15 pm    Post subject: Reply with quote
i have the same problem but seems to comming from the front end. iv'e ben driving it like that for over a year now and no change!! eeek . i to have not had the luxury of a pro and am probly gonna just let it become someone elses prob.... Finger
chrome don't get you home!!
coconutwil
PostPosted: Mon Oct 09, 2006 5:41 am    Post subject: How long? Reply with quote
My experience has been, it will last for 32.5 days and 6 hours.
