Won't Idle
baj764
PostPosted: Wed Aug 10, 2005 10:35 am    Post subject: Won't Idle Reply with quote
I have a 2000 Grand Cherokee Laredo. 4.0L Striaght 6. 2WD. It will start and continue running as long as you have your foot on the throttle. When you drop to idle it will die. Any ideas?
Thanks,
baj764
CoreyXJ
Turkish
Turkish
PostPosted: Wed Aug 10, 2005 12:55 pm    Post subject: Reply with quote
Sounds to me like its the idle air control motor. It might also be called a stepper motor. Its either gotten stuck, unhooked, or has just plain crapped out on you. Its on the side of the throttle opposite the throttle position sensor. Take it out and see whats up, chances are you'll have to just replace it.
CoreyXJ
baj764
PostPosted: Wed Aug 10, 2005 3:40 pm    Post subject: Reply with quote
Guess what..............It was an almost dead battery. Still under warranty from Sears so only $15.99 labor for a new one.
baj764
