The sized up Bolts!!!!
boncur
PostPosted: Sat Aug 13, 2005 6:03 pm    Post subject: The sized up Bolts!!!! Reply with quote
Ok here"s the deal:
Two fo my bolts seized up in the metal sleeve inside the bushing on the rear leaf springs. What should i do???? Cut the bolt drill it out???
PostPosted: Sat Aug 13, 2005 9:38 pm    Post subject: Reply with quote
When you say "seized" you mean they just won't turn? XJ's (well...Jeeps in general) are known for stubborn bolts. Have you soaked them with PB Blaster? Try tapping the bolt heads with a hammer, then re-soak in Blaster. You can also try using a torch to heat the bolt...that can also free them up.
The only one that is forgiving is the lower shackle bolt...if you cut/break it just replace the nut and bolt. If you cut/break either the forward spring eye or the upper shackle bolt (or break the weld that hold the nut inside of the frame rail) it's a world of hurt since you'll be cutting into the deck to fix it.
Of all the XJ's I've lifted, I've never had one break on me...and most of those lifts were installed before I owned air tools. I have read about people who have broken them...mostly due to haste. Just soak them down, tap lightly, heat them up, tap a little harder, soak again....then take your time and coax them out.
rvwalke
PostPosted: Sun Nov 12, 2006 4:22 pm    Post subject: Reply with quote
i had to cut mine tongiht, now i need to find out what thread pattern they are to replace them... anyone please help!
