Sluggish Jeep
Gamgan
PostPosted: Sun Aug 14, 2005 12:23 am    Post subject: Sluggish Jeep Reply with quote
My TJ98 didnt want to go past 50mph, and up a modest slope it slowed down to 20mph
So I took it to the guy who also fixes the ambulances where I work, he took it to a friend who put it on a scanner, said something about oxigen sensor ( I have no idea what he was talking about)
He tells me to go get the catalist replaced , he thinks its broken and plugging up my exhaust and plugging up my jeep
So I take it to a muffler shop, the guy there says the catalist broke in the inside and all the carbon? broke loose and plugged up my pipe too, so he changed my catalist for $95 ( I can see a HUGE diference in my jeep now) but he recommended I change the pipe too ( $45 more ) Ill do that this week then get it scanned a second time to make sure that no sensors where messed up
By the way my gas millage was worse then ever when my exhaust was plugged up, now Im back to my terrible but normal 14mpg
guesswho369
PostPosted: Mon Sep 12, 2005 5:30 pm    Post subject: Reply with quote
Do you have a 4 or 6cyl? What wheels/lift do you have? I just bought into a TJ myself about a month ago wihtout knowing much about what I was buying and hacve been trying to improve mileage myself. I think it';s probably the tires that are giving me the sorry mileage, as I've put an aftermarket header (banks) and a Magnaflow catback on since I got it. I also changed the air filter, plugs, distributor and wires hoping to gain to little effect. I like the 33-inchers but spend considerably more time on-road than off, so I'm thinking about swapping them for 31-inchers instead.
97 TJ, 4cyl
33-inch tires
3-inch lift
Gamgan
PostPosted: Fri Sep 23, 2005 7:17 am    Post subject: Reply with quote
no lift that I know of, bought it used and it already had 31' tires, so I had to put 2 washers in the wheel stops to keep them from rubbing againts the chassis
I ended up changing the pipe and the catalyst (Sp?) converter , that fixed the problem they where both busted up and plugged
I have changed the air filter, spark plugs and thats it, I need to change the wires, distributer cap and I think its time to change the gas filter, because its starting to feel clogged.
guesswho369
PostPosted: Fri Sep 23, 2005 7:34 am    Post subject: Reply with quote
I read somewhere (maybe in this forum) that NGK plugs, wires, etc have the lowest resistance and thus help improve gas mileage. I'm going to be putting a gas tank skid plate on this weekend so I'll just replace the fuel filter while I've got it down.
Keithtj
ARLI$$
ARLI$$
PostPosted: Fri Sep 23, 2005 8:00 am    Post subject: Reply with quote
Mine broke also a while ago and it sucks driving like that. Now in KY you don't even need one.
My Morning Jacket
