I love my jeep. But she needs a little help
Dan
PostPosted: Fri Aug 19, 2005 4:42 am    Post subject: I love my jeep. But she needs a little help Reply with quote
I am having 3 major problems with my 98 JGC. I will list these in order of annoyance.
1. The first is a clicking noise coming from the rear. The clicking gets faster as I accelerate and slower as decelerate and goes away completely when I press on the breaks. I was thinking it was a caliper however I just replaced the back left one about a month ago and the back right one seems to disengage. How far should the caliper piston move if it was working properly (say if I was measuring the distance between the break pads)?
2. When I go to start my engine it doesn’t always turn over for about 7-8 seconds. However, if I let it rev for about 1 second then let off then go to start it again it will turn over immediately and I can smell some exhaust coming through the vents on the dash. Also, sometimes when I go to turn it over that second time after the 1 second “prime” it makes that grinding noise like the noise you get when a car already started and you try to start it again. This problem also seems to change with the level of gas in my tank; normally on a full tank to ¾ of a tank I don’t have this problem. And it worsens as i get closer and closer to empty
3. My shifter is loose and when the car is in reverse i have to push the shifter forward to hit the switch to turn the reverse lights on.
Any and all help would be appreciated. THANKS
Clean your engine. It will thank you.
PostPosted: Mon Aug 22, 2005 3:39 pm    Post subject: Reply with quote
1 change your rear U joint...
2 Sounds like you might have a bad ignition switch.. But if it does it that way every single time?????????? I dont know..
Also the grinding is probobly a starter or flywheel issue.. (Pull the starter off and get it checked.. And while its off check your flywheel.. Make sure no chipped teeth... )
3 Take it to the dealer ..There is a recall on Shift detent they will fix it for free...
Dan
PostPosted: Tue Aug 23, 2005 4:57 am    Post subject: Reply with quote
thanks for the help swampy i'll check that stuff out
