Carb settings
wqrt
PostPosted: Tue Aug 30, 2005 6:17 am    Post subject: Carb settings Reply with quote
Anyone know how many turns out the screws need to be set at on a Carter Carb?
PostPosted: Wed Aug 31, 2005 8:08 am    Post subject: Reply with quote
What year? Are you trying to set the idle speed or the mixture?
wqrt
PostPosted: Wed Aug 31, 2005 8:58 am    Post subject: Reply with quote
1980 CJ7 with the 258 6 in it. What are the settings for both. I don't know too much about engines, I know there are 2 screws on the front of the carb. Is one for mixture and one for idle? If so which one is which and what are the settings. Thanks.
PostPosted: Wed Aug 31, 2005 10:33 am    Post subject: Reply with quote
Ok, if you're looking at the front, there should be a circular caover over the choke. At the bottom of the carb are two screws, one with a spring on it. Are those the ones you're looking at? The one with the spring is the idle speed screw. The other should be the idle mixture screw. To adjust them, you'll need a vacuum gauge and a tach. But before you do that, take a look at these:
http://www.yellowjeep.org/Carb.html
http://www.jeeptech.com/wiki/index.php/Engine/Carter
