converting 4x4
daniel_1988
PostPosted: Tue Aug 30, 2005 8:22 pm    Post subject: converting 4x4 Reply with quote
i have an 86 cherokkee 2.5 4sp can i take np231 out of another and put on my 4sp or what i need to make 4x4 i know where a few parts jeep are most are 6cyl aut though never seen a 4sp 4x4 anyways thanks for help
also planning to do sbc 700r4 swap soon i already have parts i need transfer case ive heard tou can use 4x4 s10 case ?any ideas
86 cherokee 4.5 in lift with 235/75/15 neeed biger tires it sucks
PostPosted: Tue Aug 30, 2005 9:26 pm    Post subject: Reply with quote
So your's is a 2WD now? In '86 they used the NP207 and the NP228/NP229 t-cases with (in the case of the 4 speed) the Aisin AX4 and the Borg Warner T4. I honestly don't know if a NP231 will swap right in.
In general, to do a conversion, you'll need a front axle, front driveshaft, the t-case, a transmission (or at least the tailcone from a matching 4x4 tranny) as well as the entire t-case linkage assembly.
If you are going to do sbc/th700 swap, why are you worried about putting in a 231 with the existing drivetrain?
daniel_1988
PostPosted: Tue Aug 30, 2005 11:00 pm    Post subject: Reply with quote
becaust that will come later i just need to know what t-case and maybe?tail housing i need would like to use np207
daniel_1988
PostPosted: Thu Sep 15, 2005 7:38 pm    Post subject: Reply with quote
no one knows huh?
PostPosted: Thu Sep 15, 2005 7:54 pm    Post subject: Reply with quote
Didn't realize that this was a question....it depends on which tranny you have. You'll need a tailcone from the same tranny that has a 4x4 tailcone.
So if you have an Aisin, you'll need the 4x4 tailcone from an Aisin. If you have a Borg Warner, you'll need the 4x4 tailcone from a Borg Warner.
